Screwfix HSS Tap & Die Set
Discussion in 'Engineers' Talk' started by Guy, Jan 18, 2004.
  1. Guy
    Guy Member
    Anybody had experience of this Tap and Die set (quote 12834)?
    Is this truly a quality item, or a kids play set?
    It will be for occasional use only, but I do want reasonable quality.
    If anybody can suggest other retailer for a good set, I will be grateful.
    Don't want anymore expensive than £50.00ish.
    Thanks.
  2. locustman
    locustman New Member
    Maybe better for you to buy asyou need them. Your paying for sizes you may never use, you will also get better quality.Last ones I bought M6,taper,2nd,plug tap set were about £8, good make as well, presto or goliath I think.Most common are the metric coarse threads, if in doubt take a sample along.Hope this helps.
