Screwing piano hinge into 18mm ply
Discussion in 'Carpenters' Talk' started by gongoozler, Dec 3, 2018.
  1. gongoozler
    gongoozler New Member
    Hi,
    I am trying to join two sheets of 18mm hardwood ply together with a 6' piano hinge for a sofabed. There are about 30 ~3.5mm holes on each side of the hinge for some sort of screw.
    I was wondering how best to attach the hinge. My thoughts were to use 3x16mm screws (eg https://www.screwfix.com/p/turbogol...k-multipurpose-screws-3-x-16mm-200-pack/16957) - though I'm not sure if this is the best option.
    Any thoughts would be much appreciated
  2. chippie244
    chippie244 Well-Known Member
    That should be fine, I presume you're butting the 2 sheets together and laying the piano hinge on top.
  3. gongoozler
    Exactly, then they will sit on top of a box with storage underneath. Thanks for the quick response
  4. chippie244
    I would use spruce ply though, it's lighter.
  5. gongoozler
    It's too late for that unfortunately!
  6. chippie244
    No problems.
  7. candoabitofmoststuff
    candoabitofmoststuff Active Member
  8. chippie244
  9. candoabitofmoststuff
    Even allowing for the thickness of the hinge itself?
    Cando
  10. chippie244
    Piano hinge is well thin, I doubt you'd get away with it.
  11. gongoozler
    Yeah the hinge is about 0.5mm
    While we're here, I'm planning to screw and glue some other sheets of 18mm ply to 44mm birch legs to make the box underneath. I was thinking regular wood glue, but that I would need a fine rather than coarse screw as it's going into hardwood - is this right? And also, what length of screw would be suitable for this?
    I heard a rule of thumb that was along the lines of 1.5x the length of what you're screwing through...
  12. candoabitofmoststuff
    Ahhh! I stand corrected!
    Cando
  13. chippie244
    Just use soft wood 44x44 legs, if you've bought Birch then take it back or burn it, you will regret using it if you do.
    Use 45/50 x 4 screws, countersink the heads, PVA if you like.
  14. gongoozler
    Ah ok, I was sold them as being the best for the job - what's the problem with it?
    I'll see if they have anything different in any case. Thanks
  15. chippie244
    Birch legs, so hard you won't get a screw into it, Buy some 44x44 from Wickes or B&Q.
  16. Pollowick
    Pollowick Well-Known Member
    KIAB likes this.
  17. KEVIN NAIRN
    KEVIN NAIRN Member
    When I was in shopfitting, we used a special technique to screw thin hinges or metal to wood: drill a CSK hole in hardwood or steel, place the hole of the hinge over the CSK (or drill pilot holes in the sheet metal and place over the hole) get a big centre punch and hammer the thin sheet into the CSK. This is known as "coining" you will need to CSK the ply to allow for the coined metal to be let into the surface. If done carefully, you can get a flush surface. By the way, Screwfix turbogold screws are pretty good, I use 1000s of them. Maybe not the best quality, but ok for most jobs (like screwing floorboards to joists with 5mm x 50mm). Kevin
    chippie244 likes this.
  18. KEVIN NAIRN
    KEVIN NAIRN Member
    The point being that you can't CSK thin metal. you'll just make a big hole. I will up load a picture of some thin steel angle "coined" so that the screwheads are flush or slightly below the surface.
