Sealant for cooker
Discussion in 'Screwfix' started by Clg2024, May 31, 2024.
  1. Clg2024
    Clg2024 New Member
    Got a gas cooker and the edges around the cooker gets dirt trapped.
    What type of sealant should I use? Sanitary? Heat resistant?
    I’m looking for a clean one
  2. I’m not sure you should be using anything on a flueless gas appliance that is against manufacturers instructions. Is it not possible to clean the cooker?
  3. Clg2024
    Clg2024 New Member
    it’s tricky and gap quite big for dirt to get trapped in
  4. Mark DM
    Mark DM Screwfix Select
    If you are referring to a free standing appliance then can you close down the gap with aluminium worktop trim? Intumescent sealer could be another option and could be cut through if appliance needs removal
  5. DIYDave.
    DIYDave. Screwfix Select
    Or does the OP mean a gas hob perhaps ?
    More info required
    Mark DM likes this.
  6. Mark DM
    I wondered too. Starting replying as though a hob and then thought maybe not. Definitely more clarification needed
    DIYDave. likes this.
