I am installing a woodburning stove and need to connect a piece of stovepipe between the cast iron stove top and the flexible chimney liner. does anyone know what kind of sealant or cement I will need on the joints. Many thanks in advance.
Pack the spigot on the fire with ceramic rope, sealed with fire cement. Use the correct clamp for the flexi liner to the stove pipe. Make sure you get the right flexi liner for the fuel you intend to burn. Martin
Is this in your own home, or a paying job. I strongly suspect that you aren't HETAS. If you're asking such basic stuff, what chance of you knowing rules on register plates, soot doors and flue liner - etc
Thanks Heatyman can the adaptor between 6" enamel stove pipe and flexible liner be sealed with fire cement or is a flexible sealant needed,it is about 1200mm away from the stove. Mad max you are right in suspecting I am not HETAS and it is for my own home.For what its worth I strongly suspect you are the sort of bore who can,t scratch his backside without consulting the regulations.I obtained the correct liner and flue by ringing a supplier and asking for a flue and liner for a multifuel stove,difficult stuff for a non hetas member.
If you had bothered to take any notice, you would observe that I don't randomly insult contributors, or indulge in childish and petty name calling. I stand by my query and statement . Yes, I do follow the rules, and take safety seriously. In my view, you shouldn't be fitting this stove - a solid fuel stove is potentially more dangerous than a modern gas boiler. There has been a huge increase in sales of multi fuel stoves, and, sadly I predict a rise in fatality or incidents associated with CO poisoning. I would be interested in knowing wether any other guys share my misgivings.
no, its strieght up! its just ive come across white stuff that looks like fibre glass but unsure about.
Your supplier of the other flue parts should be able to provide the correct clamp for the equipment he has already supplied. If you feel the need to supplement the arrangement with a sealer, then you will be better off with some Purimachos F.J.C., which is a flexible flue jointing compound and does 'what it says on the tin'. It stays flexible and takes up expansion and contraction. I took your original post as meaning you are lining an existing chimney. If you are not, then be sure to consider all the aspects of firestops and spacers through the rise. Martin
There has been a huge increase in sales of multi fuel stoves and, sadly, I predict a rise in fatality or incidents associated with CO poisoning. I would be interested in knowing wether any other guys share my misgivings.
Yorkshireboy, I strongly suggest you check your insurance. If you are fitting a log burner and it doesn't have a fitting certificate, you will NOT be insured. I am a huge DIY chap and I would not fit one myself. I watched and helped my installer fit ours and there are numerous things I didn't know but which are seriously important to safety. Saving money is fine, but at what price, the safety of your family. Madmax is absolutely right.
