Securing outdoor cast iron bench to the ground
Discussion in 'Carpenters' Talk' started by Mypyh4oo, Sep 11, 2021.
  1. Mypyh4oo
    Mypyh4oo Member
    Hi guys,
    Not sure if this is the correct sub but I didn’t find anything relating to the question above.
    I am wanting to secure down an outdoor bench to the ground which will be placed at the front of the house.
    can anybody please point me in the right direction? I’m not sure what sort of fixings I’d be looking at. The bench is cast iron if that helps.
    many thanks
  2. CGN
    CGN Screwfix Select
    Concrete, slabs, tarmac, block paving?
  3. Mypyh4oo
    Mypyh4oo Member
    Block paving, thank you
  4. CGN
    CGN Screwfix Select
    have you got a photo of the bench...will help?
  5. Mypyh4oo
    Mypyh4oo Member
    Apologies.
    Here it is. Thank you
  6. CGN
    CGN Screwfix Select
    no need for apologies :)
    Are you worried about it getting stolen?
    At the moment, the only thing that springs to mind would be some ‘L’ brackets fixed to the pavers and bent slightly to the angle of the legs. You’d need to drill a hole through them and use a nut and bolt to fix to the bracket. Ideally you’d want some stainless steel brackets and nuts and bolts.
    Concrete screws would probably be my choice to fix the brackets to the pavers, although you could use screws and plugs. Either way just go steady drilling the pavers.
    Mypyh4oo likes this.
  7. Mypyh4oo
    Mypyh4oo Member
    Thank you for your reply.
    To be fair I don’t think it will get stolen as it’s a safe area but you never know.. I’m confident about fixing to the ground but it’s the bench itself that I will probably struggle fixing the brackets to. Can you please give me an example of what I’d be looking at when fixing the bracket to the legs?
    Thank you again
  8. CGN
    CGN Screwfix Select
    you’d need some drill bits for steel. Small pilot hole and work up to required size for your bolts.
  9. malkie129
    malkie129 Screwfix Select
    My 1st choice if possible would be drill the feet and then use thunder bolts.
  10. WillyEckerslike
    I'd be tempted to fit a discreet ground anchor and use a decent bike lock or similar so that you can move it easily should you need to. It might look naff though if you cannot conceal the lock in any way.
    pppmacca43 and CGN like this.
  11. CGN
    CGN Screwfix Select
    probably the best and easiest way Willy.
