Selecting a car or car derived van to tow a caravan?
Discussion in 'Car and Van Talk' started by MGW, Aug 6, 2018.
  1. MGW
    MGW Screwfix Select
    It seems I made an error, I looked up the towing capacity of my car on internet, there should it seems be a VIN plate, but I couldn't find it, thought it could tow 1400 kg caravan unladen is 1250 kg laden 1450 kg, but looking at registration document seems car is 1250 kg max. (Kia Carens)
    So need a new tractor, well not new, second hand is better option, but want at least 1500 kg towing capacity. However listing likely cars, again internet shows tow weights but some models it varies widely Peugeot 3008 for example 500 -1500 kg and mile per gallon even worst, 48.7 - 70.6 mpg depending on exactly which model. As to towing mpg Nissan X-Trail light 48.7mpg and towing 23.4mpg.
    So looking to spend around £15k and want second hand, and if I can automatic, I want light mpg over 40, so it would seem needs to be diesel. I have a list of around 60 cars, only van Vauxhall Astra as all other car derived vans don't seem to have towing capacity.
    I want to carry push bikes, seems 4 options, on back of car, on top of car, on caravan A frame, or inside car, inside better security but likely to damage car getting in and out, on top OK with low car but high cars can't reach, and back of car and A frame may be damaged on a tight turn.
    So any suggestions please.
  2. KIAB
    KIAB Super Member
    A few of VW Passats can manage 2000kg brake trailer.
  3. HappyHacker
    HappyHacker Active Member
  4. The Teach
    The Teach Screwfix Select
    Skoda superb :)
  5. DIY womble
    DIY womble Well-Known Member
  6. MGW
    MGW Screwfix Select
    Well ended up with another Kia a Sorrento which will pull 3000 kg and was a lot cheaper than I extended paying.
    It will not do the miles per gallon, but one can buy a lot of deisel for the money I have saved buying the older car.
  7. jonathanc
    jonathanc Screwfix Select
    Land Rover defender. Tow anything u want
    And yes before anyone says, prone to breakdowns. Particularly the 2.2 puma is prone to output shaft failure....
  8. sospan
    sospan Screwfix Select
    I was going to suggest a Seat Leon or Vauxhall Insignia but when I looked they had a surprising low towing capability 1450 kg for a braked trailer. Even things like the modern Vitara are quite low.
    Some of the Mondeos are quite good tow cars and generally reliable and good to drive - but they are a Mondeo
    The other ones are a Merc C class or BMW 3 very good tow capacity up to 1800 kgs
    Funnily enough I am in two minds about getting a second vehicle - I quite fancy the new Ssanhyong Muso - which can out perform a Ford Ranger for towing and carrying.
  9. glob@l
    glob@l Active Member
    Have you thought about a pick up?
  10. Sparkielev
    Sparkielev Screwfix Select
    Dont they have mercedes engines ? you get a lot of car for decent money
  11. sospan
    There was a tie up at one point, I couldn't find when or if it finished. As well as being able to carry 1 ton it can pull another 3.7 at the same time - plus it comes with a 150,000 mile warranty
    Sparkielev likes this.
  12. chippie244
    chippie244 Super Member
    Monroe's are great cars for the money.
  13. Isitreally
    Isitreally Super Member
    Monroe make good shock absorbers, as for whole cars, I'm not sure, :D:D:D
  14. Sparkielev
    Was at a dealership last year looking at cars they had full range of ssanyhong was impressed at what you got for your money
  15. chippie244
    Kin spell check ;)
  16. chippie244
    Dyslexia?
  17. Sparkielev
    Did i say ssanhyong should read Ford
  18. chippie244
    I couldn't say ssanhyong if you paid me :)
  19. Sparkielev
    Not a car to buy if you have lisp
  20. chippie244
    I can't even say lisp
