Self levelling screed
Discussion in 'Other Trades Talk' started by lazyfrau, Jul 23, 2018.
Tags:
  1. lazyfrau
    lazyfrau New Member
    Hi, tried this on builder’s talk, no replies so thought I’d try it here.
    A question from a newby.
    Floor under the fridge v uneven. If I use self levelling screed will it:
    A. stick to wooden baton?
    B. Set if one area is about 3-4cms deep?
    I only want to cover about 1sq m
    Thanks.
  2. DaveF
    DaveF Active Member
    It's difficult to suggest anything without seeing the problems. Do you have a photo?
    KIAB likes this.
  3. KIAB
    KIAB Super Member
    We like our photo's.
  4. chippie244
    chippie244 Super Member
    Why not just level it using the built in leveling feet?
    lazyfrau likes this.
  5. lazyfrau
    lazyfrau New Member
    Hight dfference is too great, the little feet started to get a bit wobbly.
  6. lazyfrau
    lazyfrau New Member
    Sorry no pics at the mo.
  7. CGN
    CGN Screwfix Select
    Beer mats aside, a few shims of ply screwed down to allow the feet to be adjusted
    Or, screw 6mm tile backer board down (need to stick it with adhesive too) then self level over that after creating a dam around the perimeter.
  8. DIYDave.
    DIYDave. Screwfix Select
    I’ve only used Mapei Self Leveler myself, it’s a nice drop of gear :)
    Max pour depth in one hit is 25mm but, no problem adding additional layers after allowing each layer to cure
    When you ask will it stick to wooden batten, do you mean floorboards ?
    As fridge is going over this section it doesn’t really matter if it sticks or not, it won’t be going anywhere ;)
    If you was then laying laminate over leveller, then yep, you want it well bonded so additional prep
    Need to plug any holes or gaps between floorboards / batten (?) before you pour otherwise you will loose the mix, it goes down pretty runny
    Can use a no nails type gun adhesive or spray foam to fill gaps and holes
    As above suggestions, can always level floor with say a 25mm pour then make up finished height with timber, cement board, etc
  9. CGN
    CGN Screwfix Select
    Why risk it delaminating from floorboards then fudge about putting cement board on top?
    Cement board then leveler on top is the correct way.
    A confident delivery Dave, but content is s***e :D
    KIAB likes this.
  10. DIY womble
    DIY womble Well-Known Member
    You have a certain talent for making friends , top advice as usual though
    CGN likes this.
  11. Astramax
    Astramax Super Member
    Why is the floor that uneven, has it collapsed? treat the cause not the problem!;)
    KIAB and CGN like this.
  12. DIYDave.
    How’s the SL gonna delaminate when there’s a fridge plonked on top of it ?
    Surely weight and gravity will keep it in place ?
    Can always SBR floor 1st to ensure a good bond
    If floor is that wonky, (OP has said ‘very uneven’) you place cement board over floor then self leveller, your gonna have voids under cement boards and possibly some rock n rollin
    Several ways to do most jobs, yeah some right, some wrong, some just personal preference
    Thanks for the good and bad feedback though, great to hear there’s some postitives to my post :D
  13. Astramax
    Place a chunk of wood under the offending foot, level it up and forget about it, job done.
    KIAB and DIY womble like this.
  14. Astramax
    Best suggestion yet, simple and to the point, why over complicate simple challenges!
  15. DIY womble
    Sheet of tesco plastic bags , always a bag of multi hanging around,
  16. CGN
    CGN Screwfix Select
    As I said, you put adhesive under cement board before screwing it down.
    What happens when the fridge is removed?
    Either way, it was a brave attempt Dave :D
  17. CGN
    CGN Screwfix Select
    Don't push it :D
    DIY womble likes this.
  18. DIYDave.
    So why is it recomended when using Hardie Boards (as an example), over uneven floorboards, that you lay a thin bed of tile adhesive over floorboards before placing Hardie Boards ?
    Takes up any unevenness in floorboards and gives the Hardie Board a solid, level base to sit on with no voids - perhaps ?
    So if OPs floor is very uneven, why mess with blobs of grip fill to try and fix/level cement board before laying self leveler
    Why risk having a void under cement board and SL just where a fridge foot is gonna land
    Anyway, whatever, we all have differant ways, as long as a good result, who give a flying f uck
  19. CGN
    CGN Screwfix Select
    Is it the time of month Dave?
    Go back and read my first post. Check the 'brackets'.
    Hot weather and Gin is a good/bad combo!
  20. CGN
    CGN Screwfix Select
    I get on with most people Womble. I'm actually quite quiet and sensitive.
    I'm the first to admit, that I don't know it all, and I also have a belief system!
    I also have an ego, and I will exercise it when I believe necessary! :D
    Jord86, KIAB and Astramax like this.
