Evening all, I have previously knocked off some old lime plaster adjacent to my chimney and there is some sort of settlement crack in the wall. I was going to get a plasterer to strap and render with cement before skimming... But I was considering just dot and dabbing over it with board, as its a nightmare getting anybody who isn't bogged down with work. Does anybody have any advice what if anything needs doing if I was to plasterboard over it? Attached is a photo. Thanks!
It may be just me, but I think I can see a distinct colour difference in the bricks either side of the crack. Is it possible an old window or similar opening has been bricked up in the past and the bricks toothed in? If this is the case, there is less cause for concern. Looking at the limited information available from the single photo, it looks like the bond differs too which suggests the left side was added at a later date than the right side.(or vice versa)
I'm pretty sure it's the first time it's seen the light of day since the house was built 100+years ago... The plaster wasn't cracked but because it was so old I took it down. The very original stuff. I've attached another pic... To the left is a chimney breast and to the right is the front wall. The mortar is all old lime besides 1 splodge I'd thrown in when I had some to use up. Think I'm just gonna get some crack stitches and resin and fire them in... Unless anybody has other ideas? It's probably been there for decades
My gut feeling is that there isn’t enough length of wall either side of the crack for a helical bar and resin crack stitching kit to be effective.. Can’t guarantee this is correct, but may be worth checking out before spending out.. If the plaster wasn’t cracked, I don’t think you need to take any remedial action tbh.
The whole width of the thing is about 90, so would only get about 400mm either side of the crack at best. Better than nothing though I guess...
There was no crack in the render you removed you say so the chances of any recent movement is remote and as others have said there has been work done there at some point in time: wartime bomb damage perhaps? I would personally Helibar it for what they cost, but another option would be expamet across the whole area.
I really don't think it's been repaired.. All the walls look similar with messy mortar and odd bricks etc. Like the internal walls are just thrown together. I've ordered some helibars... Do you have any advice on what to bed in the bars with? Is this stuff OK? https://www.screwfix.com/p/rawlplug...rZoI7lHTq9ho91BNyDIaAoJxEALw_wcB&gclsrc=aw.ds
