Shaving corners off fireplace/chimney breast recess
Discussion in 'Getting Started FAQ' started by LeeBee75, Apr 27, 2018.
  1. LeeBee75
    LeeBee75 New Member
    Hi - want to install an old edwardian fireplace upstairs with tile 'cheeks' - however, as the tiled panels incline inwards, many don't fit our recess of 53cm. Would we be able to shave the corner off either side of the opening (I'm finding it'd typically be c.10cm on each side), to accommodate? Thanks.
    (This is a fireplace I'm currently eyeing up online if it helps :) )
  2. KIAB
    KIAB Super Member
    Got a photo of present opening where you want to place it.
  3. LeeBee75
    LeeBee75 New Member
    Haven't been able to get the surround off yet, so not sure how useful this will be - will get the bolster out later and repost.
  4. rogerk101
    rogerk101 Screwfix Select
    From your photos it looks like you'd have almost nothing left of your sides if you took 10cm off each of them. I wouldn't do it.
  5. KIAB
    KIAB Super Member
    Thanks, you might find once you remove surround, fireplace opening has been reduced down in size, not unusual, but a bedroom less so.
    But, I think you might end up looking for a smaller fire grate to fit opening, will be a lot easier.
    LeeBee75 likes this.
  6. rogerk101
    After reading KIAB's response above, I took a closer look at your photos, and I think you might be OK. (My fireplaces and chimney stacks protrude from the walls, hence my negative response above, but yours are recessed into the walls, so you should have plenty of support to be able to take 10cm off each side. You may find a lintel in there when you remove the marble surrounds, in which case you may need arched corners to keep the lintel supported.
  7. KIAB
    KIAB Super Member
    It very difficult working from a photo, & being 100% right, also that surround pinches some of the width of the opening.
    Once surround is removed, plaster cleared back abit, then we can get a clearer picture.:)
  8. LeeBee75
    LeeBee75 New Member
    Thanks - pic might be deceptive, the chimney breast's about 140cm wide, opening 53cm. I guess once the surround's off, we'll have a better idea of any brick-up jobs, and lintel size. There are other smaller recess options, but it's quite a big room, so ideally wants a big feature (on a shoestring budget, fun challenge...)[​IMG]
