Shed build
Discussion in 'Project Photos' started by FatHands, May 7, 2016.
  1. FatHands
    FatHands Well-Known Member
    Thanks to everyone who has helped me with this. Some pictures attached:
    shed_base_for_sf_forum_3.jpg shed_base_for_sf_forum_1.jpg shed_base_for_sf_forum_2.jpg
  2. KIAB
    KIAB Super Member
    Looking good.:)
    I spy BBQ [​IMG]
    tore81 likes this.
  3. chippie244
    chippie244 Super Member
    Over engineered :):)
  4. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Check your levels. I think it's low this corner!
    Mr. HandyAndy - Really
  5. FatHands
    thanks for looking everyone. mrs has never worked so hard ;)
    K - yes bbq last Thursday and Friday. Couple of Golds to wash it all down too :)
  6. longboat
    longboat Screwfix Select
    Where's the shed?
  7. Phil the Paver
    I've got exactly the same trolley Jack. :)
    Springs on the trampoline look a bit rusty. :(:(
    shed base looks good though. :)
  8. longboat
    Have you poured the concrete in the holes yet?
  9. FatHands
    Phil - i bought that from Brown Brothers (they used to sell automotive paints and body panels but think they have ceased trading now) years ago and still going strong :) Yeah rusty so need to keep an eye on those.
    Concrete all in now
  10. chippie244
    Is that a shed base or a missile launching platform? :eek::eek::eek:
    georgemcintyre likes this.
  11. Jitender
    Jitender Screwfix Select
    That's probably my fault :oops:
    Nice neat job with evenly spaced fixings, will you be putting in steps?
  12. Jitender
    Did you spot the laser level? :)
  13. chippie244
    Is there a missing post on the right?
    Lovely job BTW.
    tore81 likes this.
  14. longboat
    And left!?
    Cracking work, what are you using for the floor?
  15. FatHands
    Thanks for all the posts chaps. 2 of the posts were knackered and the mixer has to go back tomorrow so (rightly or wrongly!) i decided to infill and will make those 2 in the picture up with courses of bricks which will have the benefit of supporting both spans.
    Jit - i am going to put some steps in (suggestions welcome ;))
    Longboat - 25mm exterior ply which i was going to SBR the underside prior to screwing down
    Chips - original plan was a shed, but changed to rocket launcher now mate :p:D
  16. chippie244
    Just make sure you hit Luton.:p:p
    georgemcintyre and malkie129 like this.
  17. Phil the Paver
    Nearly.
    The rear noggins are right of the front on 2 and left on the other.
    Still a very substantial base though, lets hope the shed as good.☺
  18. Jitender
    Stairs
    You could use 600x300mm concrete slabs as the steps, built on brickwork or concrete formed base.
    Or maybe 900mm wide? may be better for extra width.
  19. FatHands
    I did it this way as they were a tighter, squarer fit. One thing that i find hard working with timber is the way it can bananarise overnight!
    Thanks, i think i will go for 900mm possibly and double doors
  20. Fats is turning shed-building into an art-form :D
    Man, I can't believe you are going to hide all that lovely work up by putting a shed on it...
    The 'missing' posts along the two sides - are you going to add supports there instead, 'cos these side bearers look like they are currently only being supported by 3 bolts into their ends?
    FatHands and KIAB like this.
