Shed build
Discussion in 'Project Photos' started by FatHands, May 7, 2016.
  1. FatHands
    FatHands Well-Known Member
    thanks DA :D
    the frame is held together by 3 x turbo golds (as per chips advice) on each join and the frame is sat on dekposts with M10 stainless bolts to stop it all moving around. I was planning on a couple of courses to support the middle and vertical due to 2 posts being bollowed in transit. :(
    Deleted member 33931 likes this.
  2. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Should have slightly staggered the screws, so as not to encourage splitting.
    Mr. HandyAndy - Really
  3. FatHands
    Do you mean as in green Andy, and not red?
    tore81 likes this.
  4. Mr. Handyandy
    Yep,similar, not as exaggerated.
  5. chippie244
    chippie244 Super Member
    It wont make a bit of difference.
  6. Jitender
    Jitender Screwfix Select
    Or these? I'm sure you can get in 900mm length and wider ones to suit.
    blackteaonesugar likes this.
  7. FatHands
    they look nice jit, thanks. looks like selco and TP only do them in 600 so have enquired about postage.
  8. Jitender
    Bought some a couple of years back from local merchant, and they were 900mm long.
  9. FatHands
    local merchant down here doesnt have a website so will pop in. be a lot easier to get them locally. :)
  10. KIAB
    KIAB Super Member
    Just look for D50 paving slabs.;)
    Available in various sizes.:)
    http://www.online-building-supplies...g-slab--flag-d50--3x2-single-flag--6634-p.asp
    Also look for BSS slabs or BSS Pressed Concrete Slab, same thing just, depends where you are in the UK as to the name.
    https://www.travisperkins.co.uk/BSS-Pressed-Concrete-Slab-Natural-900mm-x-600mm-x-50mm/p/797694
    Marshalls also list 900x600mm & numerous other sizes in their commerical flag paving.
    http://www.marshalls.co.uk/commercial/assets/documents/product-specifications/paco10.pdf
    http://www.marshalls.co.uk/commercial/paving/products/standard-grey-pimple-flag-paving-webfa034540
    FatHands likes this.
  11. It is a high rise shed,there is another 4 floors to be built yet.
  12. KIAB
    KIAB Super Member
    He should have poured concrete to just below ground level,then topped with soil & grass seeded.
  13. deadbeat
    deadbeat New Member
  14. FatHands
    :p
  15. FatHands
    building myself deadbead, from 3 x 2 exterior ply and feather edge on the outside. gawd knows what i will do with the roof :oops:
  16. Mr. Handyandy
    Put it on top!
    :confused:
  17. Jitender
    Cut roof - nice plum and seat cuts.
  18. KIAB
    KIAB Super Member
    Shed with a roof top patio.:)
    [​IMG]
    chippie244 likes this.
  19. Phil the Paver
    On the base he's built he could easily have this. :D:D
  20. FatHands
    thanks jit, will do. when you say seat cuts: you mean cut the rafters so they sit nicely on the joist yeah?
    any idea on how long the concrete will take to go off completely? infil is about 300 x 300 x 600 deep
