Shock arrestor
Discussion in 'Plumbers' Talk' started by teabreak, Mar 23, 2021.
  1. teabreak
    teabreak Screwfix Select
    Hi all,
    I have always used the mini expansion vessel type, but the last two I have fitted at home have failed (from a proper supplier not an ebay special) the first leaked around the centre join after a couple of years the latest lasted about a year then the hammer returned, I checked the valve no pressure. As a temp fix I de-pressurised the supply and pumped up the vessel with a footpump. I am wondering if a mechanical one would be a better bet perhaps the Pegler or Caleffi one any thoughts please?
    I also cannot find any wras approved notation on either make which seems odd for well known brands am I missing something?
  2. kiaora
    kiaora Screwfix Select
    Hi
    If you have the room, a vertical pipe with a soldered cap will act and a shock arrester, say 15/22and a section of 22 with a cap end, vertical of course,
    mind you renewing the ball valve often stops water hammer ?
    good luck
    Peter
  3. teabreak
    Thank you Peter, I did do that at a previous house and it worked well, but when I had the combi fitted they wanted a shock arrestor in the system. All on mains now.
    Usual culprit washing machine and ΒΌ turn taps!;)
    kiaora likes this.
