Shower base, to seal or not to seal
Discussion in 'Plumbers' Talk' started by Jonathan Gale, Jan 26, 2020.
Tags:
  1. Jonathan Gale
    Jonathan Gale New Member
    I’m hoping someone may be able to help.
    There is a gap between the edge of the shower tray and where the screen/door begin.
    Should this gap sealed with silicon? Water just seems to gather in the gap but doesn’t run in to the waste pipe.
    Any advice is most welcome.
    Thanks
  2. terrymac
    terrymac Screwfix Select
    Unless water is getting OUT of the enclosure ,and into the room I wouldn't worry.
