Good day everyone.
I am a complete newbie looking for some advice from some seasoned veterans.
I recently moved into a new property with an en-suite added to one of the rooms; last night, I noticed a hairline crack running the vertical length of the shower corner grouting.
I have read that you should use caulk in corners where the tiles change planes. Is this the case, or should I be re-grouting the corner? (Please see attached image)
Furthermore, above the shower grouting, the drywall corner join has a hairline crack that may have caused the grout cracking. (See attached image)
Any advice would be much appreciated.
Cheers!
Anrich
Cheers!
Anrich
