I've just had our en-suite refitted due to a leak, have come to get a shower door fitted and found the cubicle to be about a cm wider at the top than the bottom (approx. 875mm and 865mm). Do you know if it is possible to get a bi-fold shower door that is adjustable top and bottom independently? I know lot are adjustable but none say whether its top and bottom. Like this one - https://www.screwfix.com/p/triton-f...mm/441kt#product_additional_details_container
The key thing to check is that the tray is level. 1cm difference in width can be accommodated by the amount the door slides into the wall channels either side. The door you linked to would work but you are right on the lower limit so might be quite a squeeze to get it fitted.
