Shower Head Sagging
Discussion in 'Plumbers' Talk' started by Iron_Mike, Jun 25, 2019.
  1. Iron_Mike
    Iron_Mike Active Member
    Hi
    The unit that holds the shower head in position, is no longer doing this.
    It is a Aqualisa shower, is my best bet contacting them and getting a replacement part?
    Is there a way to fix it?
    I have attached a picture. But effectively it cannot support the weight of the shower head, meaning my bath taps are continually sprayed with water, rather than myself.
    Any advice appreciated.
    Cheers
    http://imgur.com/gallery/rToGA4q
  2. just pumps
    just pumps Screwfix Select
    As a stab in the dark................. Is there adjustment screw, possibly under a chrome cover.
    Iron_Mike likes this.
  3. Iron_Mike
    Will try to expose it and see if there is a screw that I can tighten.
  4. WillyEckerslike
    Put the plug in the bath first....
  5. KIAB
    KIAB Super Member
    Is that the pinch grip shower holder?
    Iron_Mike and The Teach like this.
  6. The Teach
    The Teach Screwfix Select
    could just be the ratchet mechanism loose or broken.For some reason they made that showerhead holder over complicated they are a regular failure :(
    There around £15 to buy,some pipe dismantling will be required but depends on the model of the shower
    TT:D
  7. Iron_Mike
    Yes that is causing the problem. Not pinching tight enough.
  8. Severntrent
    Severntrent Screwfix Select
    Not the best solution but possibley wrapping some electricians tape around the head may restore the pinching action
  9. Iron_Mike
    Yes I was thinking that might work.
  10. Severntrent
    I had similar problem once and drilled hole through head and tightened it up with small nut and bolt. Use stainless if you can. Screenshot (192).png
    WillyEckerslike likes this.
  11. Iron_Mike
    Thanks fella
