Shower Hose Connectors?
Discussion in 'Plumbers' Talk' started by glob@l, Oct 8, 2019.
  1. glob@l
    glob@l Active Member
    IMG_20191008_205544.jpg IMG_20191008_205600.jpg What do you call these connectors and can they be applied to a standard hose? If not where can I get a hose with these already on?........... It's from an Aqualaisa shower so if no luck I could always contact them.
  2. KIAB
    KIAB Super Member
  3. Heat
    Heat Screwfix Select
    Aqualisa shower valves often use full bore hoses.
    But you could use any other brand that is full bore if the nuts suit.
    Some hoses use small nut on one end.
    The plastic part you have should be detachable from old hose and reusable
    KIAB likes this.
  4. glob@l
  5. glob@l
    There is a crack in the plastic connector so need a new one.
  6. KIAB
    KIAB Super Member
    Now you tell us.:)
  7. The Teach
    The Teach Screwfix Select
    Think the part is called 'aqualisa reducer kit white' and you will want a proper shower hose :)
    dobbie likes this.
  8. KIAB
    KIAB Super Member
  9. glob@l
  10. KIAB
    KIAB Super Member
    It will be 1/2" BSP thread hose end,so any shower hose will fit.
    Joe the Plumber likes this.
  11. Joe the Plumber
    Just make sure the bore of the hose is a good size. Some aftermarket ones are only 1/8" and do a great job of restricting the flow rate. In fact I had one customer who burnt out his power shower pump by fitting a new hose with a tiny bore.
    KIAB and dobbie like this.
  12. glob@l
    Thanks for that.
    The bore for the shower hose is 10mm as per the one I have, so I presume the thread will be 1/2 inch (standard) as mentioned above. As I say I nearly baught the shower hose in the link above and I remember seeing a cone shaped chrome connection on one end and I think a bolt type connection on the other, I'm hoping it will all still be compatable.
