Shower panels on to pasterboard
Discussion in 'Plumbers' Talk' started by marc_12, Jul 21, 2021 at 8:29 PM.
  1. marc_12
    marc_12 Member
    Is it ok to stick 10mm plastic shower panels straight on to moisturiser resistant plasterboard? Or do they need sealing/priming first? Thanks
  2. pppmacca43
    pppmacca43 Well-Known Member
    I can’t be certain but if the plasterboard isn’t skimmed I’d be very surprised if it needed any priming
    CGN and marc_12 like this.
  3. marc_12
    marc_12 Member
    Correct un skimmed moisture resistant plasterboard.
  4. CGN
    CGN Screwfix Select
    Stick away. Check the squareness of your panels before you cut. Had some once that where 10mm out of square. Luckily I doubled checked just before cutting. Could have been a costly mistake.
  5. marc_12
    marc_12 Member
    Thanks have you stuck them before on moisture resistant boards?
  6. CGN
    CGN Screwfix Select
    modern adhesives will stick fine to moisture boards.
  7. FlyByNight
    FlyByNight Well-Known Member
