shower pump ?
Discussion in 'Plumbers' Talk' started by apocalypse61, Nov 22, 2017.
  1. apocalypse61
    apocalypse61 Member
    Hi guys, I have a gravity fed system, approx 0.5m between header tank & shower head, for 12 years I have had a jetforce 55 (1.5 bar) feeding a single shower hand set (all 15mm pipework) providing a half decent power shower,
    have now replaced the shower with a Cassellie Deana shower (min 0.5 bar) with fixed head & hand set, the fixed head seems ok but the handset is bearly a power shower anymore, so it looks like i need to upgrade the pump ? what size pump do I need ? and do I need to upgrade the pipework as well to 22mm ? I mean it reduces to 15mm at the "t" bar anyway ?
    much appreciated,
  2. KIAB
    KIAB Well-Known Member
    The Cassellie Deana thermostatic mixer shower?
    Inlet Connection Size: 3/4 inch (22mm) if we are looking at same shower, & you have reduced it down to 15mm.
  3. Dr Bodgit
    Dr Bodgit Well-Known Member
    Pressure isn't everything, you also need to look at the flow rate the pump is capable of. Stuart Turner make great pumps, spec on their Monsoon Standard 3.0 bar pump is for example:
    Performance
    Maximum head (closed valve) 3.0 bar
    Performance @ 9 l/min 2.5 bar
    Performance @ 18 l/min 2.1 bar
    Maximum flow 60 l/min
    1.5 bar should be enough but your pump probably has insufficient flow rate. What is the make and model of your pump?
  4. KIAB
    :eek::p
    No longer made.:eek:
  5. Dr Bodgit
    Thanks, I must be blind. :rolleyes:
    Did some googling and can't find the flow rate spec on that pump. Suggest the OP contact Stuart Turner and ask them for advice on a suitable replacement pump, their CS are very helpful.
  6. andy48
    andy48 Active Member
    If the fixed head works OK it would suggest to me that the pump is adequate, but that there is something wrong with the hand held shower head set up.
    Try:
    1. Unscrewing the head, and see if the flow from the open hose end is better.
    2. Unscrewing the flexible hose from the shower body and see if flow is better.
    If 1. results in decent flow, the head may be blocked / faulty.
    If 2. results in decent flow, then the diverter valve may be faulty.
  7. Dr Bodgit
    Unless he means when the hand held is turn on in addition to the fixed head. Its not clear.
  8. apocalypse61
    apocalypse61 Member
    ah ! i didnt fit it, but the pipes going into the wall are 15mm
  9. apocalypse61
    apocalypse61 Member
    you can only have either or, can't have the overhead and the handset on at the same time
  10. KIAB
    Restrictor.
  11. apocalypse61
    apocalypse61 Member
    yeh tried that no blockage,
  12. apocalypse61
    apocalypse61 Member
    but where ?
  13. KIAB
    Connection inlets, can't find any installation leaflet for shower, OP has 15mm pipework whether this would restrict performance of shower which has 3/4" inlet not sure.
  14. apocalypse61
    apocalypse61 Member
    so, if the mixer/t bar has 22mm connections, even if i connect it with 22mm pipe i would still have to reduce to 15mm at the pump ? so no difference ?
  15. Dr Bodgit
    When you unscrewed the head or hose, how much flow was there compared to when the head is fitted?
  16. apocalypse61
    apocalypse61 Member
    just done that, with head on approx 5l/min head off 7l/min
  17. Dr Bodgit
    That's pretty poor, what about if you take the hose off the mixer unit? Wondering if there is a restrictor there or something.
  18. apocalypse61
    apocalypse61 Member
    approx 9l/min thats abpout 900mm lower down of course
  19. Pollowick
    Pollowick Well-Known Member
    Do you have any isolation valves before/after the pump? And are they fully open?
    Just to confirm that your pump has 15mm connections.
  20. apocalypse61
    apocalypse61 Member
    yep, both inlet valves to pump fully open, no blocked inline filters, 15mm pipe all the way through, i'm wondering if the Deana mixer has 22mm connections would I be better of upgrading the pump and pipework to 22mm right through ?
