Shower tray with upstand
Discussion in 'Plumbers' Talk' started by Ollieu1900, Jul 24, 2021.
  1. Ollieu1900
    Ollieu1900 New Member
    Hello,
    I have a shower tray which has 2 edges behind the bottom row of tiles.
    Any idea how to check if the tray has 4 upstands or 2 as the outer edges with the doors on have upstands. (It's a 90x90 square tray)
    Reason being a small part of the sealant has slightly lost adhesion but looks perfect on 90% of it. Really don't fancy redoing all of it.
  2. I-Man
    I-Man Screwfix Select
    Can you send a picture
  3. Ollieu1900
    I will try and take a better photo later, I know the make is "ideal standard" if that means anything?
  4. I-Man
    The front part is not an upstand, it's just a length of upvc which has been fixed on, probably with silicone.
  5. Abrickie
    Abrickie Screwfix Select
    Or it could be an Ideal Standard Idealite Low Profile Square Upstand Shower Tray, just saying ;)
  6. I-Man
    Quite possibly... But I'm willing to bet its not
  7. Ollieu1900
    I can guarantee it is an upstand on atleast the 2 sides I can see. No joint in sight or silicone. In fairness it's a poor photo so I'll try and take another
  8. Ollieu1900
    Apologies...it needs a good clean but its not been used in a while!
    I think you may be correct. Is there any ideal standard variation that only uses 2 upstands instead of 4?
  9. Abrickie
    Not that I am aware of ;)
  10. Ollieu1900
    Thanks for the reply:D
