https://www.victorianplumbing.co.uk...VDbDtCh0FWAkbEAQYASABEgLr7fD_BwE&gclsrc=aw.ds I have a 40mm solvent weld waste pipe I need to connect this thing to any idea what coupler I need? I really don’t want to make another unnecessary trip to screwfix. Id is about 36mm od 39mm. Thanks
hi https://www.screwfix.com/p/mcalpine-t28m-straight-connector-white-40mm-x-40mm/71314 but if you can, take the fitting with you, you can try befor you buy good luck peter
Have you got a 1.5” solvent coupling to try on the spigot end of that flexi waste pipe? Or a mcalpine 1.5” compression coupling?
The 1.5” 40mm compression coupler I just tried is fine for the solvent weld with a reducer, but ever so slightly too big for the shower fitting, gets tight but doesn’t grip, can just pull it out is there a 38-39mm version?
You shouldn't need a reducer on the solvent weld pipe ,and the compression coupler should tighten just fine onto the 39 mm as well ?? Is the coupler a mcalpine ?
