Sideboard top layer coating stripped by room fragrance defuser
Discussion in 'Painters' Talk' started by bond007, Jan 16, 2019.
  1. bond007
    bond007 Member
    Guys
    After a bit of advice, the sideboard cabinet had some reed defusier (room fragnace) spilled on it. Seems like it's stripped the top layer coating.
    Tried many products to clean it with but can clearly see dull patches.
    Anything you can recommend to restore the original colour back?
    Or to improve its current look.
    Thanks in advance
  2. rogerk101
    rogerk101 Well-Known Member
    Maybe you could team up with the other person on here who is complaining about the impotence of paint strippers these days. ;)
    KIAB and LGC Decorators Ltd like this.
  3. bond007
    bond007 Member
    Any update or recommendation please?
  4. Astramax
    Astramax Well-Known Member
    What products have you tried so far, have you tried polishing it using brasso, aluminium polish or even toothpaste with a soft cloth or microfibre cloth.
  5. bond007
    bond007 Member
    Tried all the standard conventional cleaners. It's stripped the top layer of coloring. I need something to restore it. Was thinking of black shoe polish?
    What material is the sideboard?
  6. Astramax
    Use wet and dry paper to flatten off the whole top and then re ebonise it. Shoe polish will not last.
    KIAB likes this.
  7. bond007
    bond007 Member
    What products will i use to re ebonise?
  8. KIAB
    KIAB Well-Known Member
    Old joiner I knew use to use India Ink,but just look Youtube for re ebonise wood for guides.
  9. bond007
    bond007 Member
    but mine isnt wood isit? its like gloss or matt .....
  10. Alphadog
    Alphadog New Member
    There is a special place in hell for people who use stink up rooms with those things.
    Having to re-ebonise your cabinet top is hopefully, mere purgatory and worse is to come.
  11. bond007
    bond007 Member
    Oh dont be saying that, dreading touching it already in that case......not a black film or something i can just stick on top
  12. Astramax
    Stick on film 'Fablon'. Re ebonising is just a term used for colouring/painting it black. Paint it matt black emulsion and use Sadolin clear polyurethane satin varnish to seal it.
  13. bond007
    bond007 Member
    Fablon film or painitng????....think i would stick with the film option. Less messy......unless anyone has other options
  14. Astramax
    Make sure the surface is clean free from any silicon type household cleaners also be aware of air bubbles.
  15. bond007
    bond007 Member
    Hi
    I went with the fablon warp advice and look at the before and after pictures.
    Thanks for all the help guys..
    Looks much better already
    chippie244 and Astramax like this.
  16. Astramax
    Nice job. :) Looking good. ;)
    bond007 likes this.
