Silicon tile & painted wood.
Discussion in 'Plumbers' Talk' started by SykesIT, Nov 16, 2020.
  1. SykesIT
    SykesIT Member
    Not sure who to ask but I have situation in bathroom where I need to silicone between wall tiles and painted wood covering the toilet pipe, basically boxed in pipework.
    Am I ok using standard bathroom silicone sealant like you do around bath. I ask as I have used silicone before on painted wood and seems to peal at edges of too thin.
    If it wasn't tile I wood use decorators caulk and gloss over to seal but can't do that with tile.
    Thanks
  2. AnotherTopJob
    AnotherTopJob Screwfix Select
    Adhesion is unlikely to be a problem with silicone if applied properly. However it means any further painting will be difficult.
    Caulk shouldn't be an issue with tiles, or you could use an acrylic sealant.
  3. Astramax
    Astramax Super Member
    Use an exterior paintable frame sealant Geocel Top Gun will be ok.
  4. SykesIT
    SykesIT Member
    The only reason I wasn't going to use caulk is I was concerned it would go mouldy in a bathroom without over painting.
  5. DIYDave.
    DIYDave. Screwfix Select
    Not sure of the exact set up but it’s basically where timber boxing meets tiles ,,,, yes ?
    Are these junctions 90 degree angles (or there abouts) Like where a kitchen worktop meets the tiled splashback ?
    If yes to the above, then either caulk and then overpaint with whatever is on the pipe boxing. Get a neat paint line at tile edge and any paint on tiles can be cleaned off easy enough (unless there unglazed tiles)
    ‘Most’caulks dry a little grey so not sure how this will look if you don’t paint
    When you say previously that silicon has peeled at edges as too thin -
    Sounds like your shaping the sili with a finger and then yes, at the edges you get whispy thin silicon that does peel
    If above is how you’ve previously applied the silicon, then it’s the wrong method at fault and not necessarily the silicon
    Silicon at a 90 degree junction should end up as a perfect wedge shape with no thin edges but a solid, triangle of silicon in the joint
    The way to achieve this is by using a silicon profile tool - many on the market, SF sell several, look on You Tube for tutorials
    Also consider a coloured silicon (if your going this route) as depending on colour scheme of tiles and pipe boxing, white isn’t always the best choice
    Again SF sell a few, many more colours available online
    Post of picture of the area, usually helps - good luck
  6. SykesIT
    SykesIT Member
    So when I silicone i tend to tape both sides and smooth off with my finger yes. Am I better not using tape as hard to get perfect position for wedge and just work with the silicone wedges as they scrape off the excess.
    The issue sometimes is the walls aren't always even so getting the best wedge size can be difficult.
    I use Unibond bathroom silicone. So would you suggest silicone or caulk and paint with gloss to match the boxing?
    Here is a picture of the boxing in.
    [​IMG]
    Thanks
  7. DIYDave.
    Ok, great to see a picture and the set up and it’s pretty much how I imagined
    Shaping the sili with a wet finger isn’t the best method / although it’s been done for ever and still is and happens on a daily basis I’m sure
    Trouble is, you don’t get that nice wedge shape and often end up with a concave shape and those thin edges that tear
    Two things when using sili;
    It’s gotta be neat
    It often highlights the junction so draws the eye to the area - using a colour other than white can help here but depends on colour scheme of background
    For me, I would caulk the gaps, twice as first application will dry and shrink back
    Caulk is water based and easier to use and tidy up with a damp finger/sponge
    Can either fill gaps and finish level and flat with pipe boxing or again, use a profile tool and go for that neat, triangular wedge shape
    Once fully dry (don’t believe the 1 hour paintable claims) leave overnight and repaint boxing and caulk - not a big job is it :)
    Painting up to tiles is the same as ‘cutting in’ during decorating where wall meets door frame, wall to ceiling, wall to skirts, etc
    Nice looking bathroom from what we see so it’s great your aiming for a neat finish and attention to detail - sadly lacking with too many people these days
    So caulk, 2 applications, profile, dry, paint, post pictures of your masterpiece :D
  8. SykesIT
    SykesIT Member
    Thanks will do that as prefer to use caulk.
    I have tarted bathroom best I can as previous owner never did anything.
    Would you do same around window were beading meets wall. I would do same caulk and paint caulk.
    [​IMG]
  9. DIYDave.
    Yes caulk again around windows and sill, easier to work with and again, can then paint right up to and including caulk line
    That way you get an invisible seam between wall and trim around window
    When you silicone around the trim, this junction becomes more noticeable - even more so if the silicone is messy
    Caulk or acrylic frame sealant, both over-paintable
