Silicone Colour - Match grout or top?
Discussion in 'Kitchen Fitters' Talk' started by Iron_Mike, Aug 26, 2018.
  1. Iron_Mike
    Iron_Mike Active Member
    Hi
    Interested to get a second opinion on this.
    Should I silicone around my kitchen splashback to match the grout colour or should I use a silicone colour that matches the tops.
    Not sure if this is purely a personal preference, but was interested to hear what people thought.
    I have attached a video.
    Any advice appreciated.
    Cheers
    IM
  2. CGN
    CGN Well-Known Member
    Usually match grout.
  3. fillyboy
    fillyboy Well-Known Member
    Or worktop.
  4. Isitreally
    Isitreally Well-Known Member
    Grout.
    Most worktops are of colours silicone isn't.
  5. CGN
    Whatever works, but if you've already bought colour matched silicon to do your internal corners, then no point in buying another colour of silicon to match the worktop.
    Any way, could split hairs for hours over this!
  6. kitfit1
    kitfit1 Well-Known Member
    As worktops are very rarely just one solid block of colour, it's normal to silicone using the same colour as the grout.
  7. DIYDave.
    DIYDave. Well-Known Member
    Get yourself a set of Fugenboy Silicon Tools, £10 eBay
    Best tenner you will spend on 3 bits of plastic
    Ditch the masking tape, no need, a little practice and some soapy suds and perfect silicon beads
  8. Isitreally
    There are good, but i would say forget soapy suds as it gets under the silicone stopping the edge sticking down properly.
    Also they are not very good on textured tiles.
  9. DIYDave.
    Apply sili to dry surfaces
    Dip tool ( :confused:) into soapy suds and shake off excess, or use a spray bottle
    Haven’t had a problem with adhesion this way but the ‘lube’ really helps when tooling and leaving a smooth surface on the sili, also excess sili just slides off the profile tool
    Oh well, we all have different methods :D
  10. fillyboy
    I've had a set sitting on the passenger seat of the van for over a year now but haven't been able to bring myself to use them yet. Must give 'em a try.
    Iron_Mike likes this.
  11. Iron_Mike
    Thanks for the tips lads.
    Will go with the grout colour.
  12. DIYDave.
    Top Tip -
    Take em out of box (and van) before using .....
    Work so much better :p
    fillyboy likes this.
  13. Muzungu
    Muzungu Active Member
  14. Richard_
    Richard_ Active Member
    Match the grout.
    Tiles should be surrounded by grout on all four sides, it looks odd if they aren't. So the seal to the worktop should maintain that visual effect by being the same colour as the grout.
    The other thing is that the tiles should look like they come down onto the worktop, but if you have the seal the same colour as the worktop it would look like the worktop is against the tiles. ... IMHO!
    Finally, decent grout suppliers sell silicon in a matching colour so it's easy choice with no effort. It will not be so easy to find a match to the worktop, especially as worktops are very rarely a flat single colour.
