Has anyone got any tips to get a stuck single lever tap handle off? And before anyone states the obvious, yes, I have undone the grub screw. The bloody thing is just stuck hard.
First spray some WD40 into the end of the handle. Then use a rubber mallet, or the rubber coated shaft of a hammer, to gently tap all around the handle without damaging it, but still enough to hopefully eventually release it from the spindle. Can take an hour with some of them in my experience, - not joking. I probably would avoid using flame heat from a torch (blow lamp) on the handle, but you could try heating it some other method
It's a single lever, the kind that does both hot and cold, see image, nowhere to spray wd40, so my usual methods and the ones you suggested aren't suitable for this type. The spindle it's stuck on is plastic so heat is not an option.
WD 40 ,point the tube into the hole where grub screw came out. Leave it for 20 mins. Pouring very hot water over the handle can help expand it .
Can i just remind you guys that normal WD40 is mainly a moisture dispersant and is NOT really a penetrant fluid....or lube. That's why they have a special one for the job.
Try 2 large flat blade screwdrivers or couple old knackered chisels slipped under handle and between tap body Trick is to lever handle upwards with equal pressure from 2 sides at the same time If you just lever from one side, handle seems to grip into plastic cartridge even more Work around the handle, wherever you can get tools into gap, but always from 2 opposit sides So yes, liberal squirt of 40 through screw hole, then 2 ‘levers’ and twist them at same time Couple kettle fulls of boiling water over handle also worth trying Agree, no blow torch. Handle sits onto plastic cartridge so this ain’t gonna help Good luck Tip - put plug in hole before removing grub screw - they have a tendency to head straight for the U bend !
Sometimes it is either the levering with a couple of big flat blade screwdrivers or new tap. No choice sometimes. Depends on condition of tap tbh. Stilsons, I know you are joking.
Are you a total knob or just a pain in the arris (at the best of times) How much are we expected to spoon feed people ?? Yeah happy to help with some advice and yes, I’ve used this method myself How difficult is it to wrap ends of screwdrivers/chisels in masking tape/kitchen roll/rag/etc Problem solved Easy innit Is that understood RS ?
Probably regarded as a pain..most times....particularly when correcting someone or pointing out inadequate/ incorrect/bad advice to guest DIYers.... who don't know much about this stuff. Things are not always obvious...like using WD40 as a penetrating fluid...instead of....'penetrating fluid'.......until someone with knowledge, experience and formal training points it out. Most DIYers do need spoon feeding. It is hard being blessed with Common Sense....as most people don't have it. Lets hope you dont end up sleeping with the fish. Capice ? RS
What possible relevance to this post can the above quote from The Godfather have I’m really struggling to see the connection here Is it maybe that you see yourself as some kind of mafia boss, sitting at your keyboard making pathetic threats whilst giving yourself a hard on (if your still capable) As I said above ........ knob You can take the cotton wool outta ur cheeks now RS
Now, now children, play nicely. RS, I was simply asking if anyone had any tips. Not to be patronised. I'm not a DIYer, but I often have problems with these devils so I was just wondering what other plumbers do when the bleeders don't want to play. Anyway, I've done the job, with screwdrivers and without your penetrating fluid - and a fair bit of brute force. Thanks all.
Good to hear that you’ve got the tap head off, was it like I said, using screwdrivers as levers ? Now it’s off, guessing it’s a cartridge problem ? So next job, matching up a replacement
Cheeks as in face Astra ...,,,, not as in Arris Still don’t get the relevance of the film quote though with regards to removing a tap head
Yes, definitely the cartridge. I've never seen one in quite so many bits. Can't get one locally today. Lovely tiled bath panel so no chance of isolating the tap. Fortunately the tap is like the one in the picture I posted. Took the mixer off the stems and popped a couple of 3/4" blanking caps on. Customer has a shower so everyone's happy until the new cartridge arrives. Jobs a good 'un.
