Hello, I had recetly fitted a new sink tap. It sits on the sink well and the sink is put in place by a brass flange nut that was provided with the Tap. (See picture 1) The problem is, the sink still moves and wobbles a lot! I've tried to make it as tight as possible but not sure why it still wobbles this much... so frustrating. Wondering if you had any suggestions on what I should try, I was wondering putting a large washer (metal plate of some sort?...) Or am I missing something else that's blindingly ovbious?! Any help appreciated
Also there was no washer supplied (or mentioned in the instructions) to put above the locking nut. If I got one of these, would it help it stop being so wobbly ?
It's partly due to the load not being spread with a large washer, but the very thin metal used in cheaper sinks oven results in a lot of flex. You can get support braces like this which will help. https://www.amazon.co.uk/dp/B00LFHRVU4/ref=cm_sw_r_cp_apa_fabc_F1QCT21V2J2S4MWHSAR4 https://www.amazon.co.uk/dp/B00SNER0OY/ref=cm_sw_r_cp_apa_fabc_21KE9BE3M3CPADK7GTQX
Yeah thought as much, I'll give one of these braces a go. I thought also to cut some thick wood to size and put in a 35mm hole and use that as a support.
Some taps come with the brace (or similar) in the box for this exact reason With this style of tap with the ‘swan neck’, the wobble factor is often worse as much more leverage and made worse by a thin stainless sink The wood brace will equally work yes, Did the same on my ‘plastic’ type bath for the bath / shower mixer taps as insane wobble factor when fitting
The wood brace would work better than the plate, especially if you go 18mm or even thicker. If you fix the wood solid it COULD be like the tap is fitted into a solid worktop, IF you do a really good job.
Yeah it Yeah I can imagine! Even just lightly poking the tap, makes it wobble like jelly I ordered the metal brace, if that doesn't work...my plan is to get the shape of the wood, as close to the amount of space I have underneath. Then drill the hole to size, take apart and use it as a big wooden washer.
