Size of worktop radius
Discussion in 'Kitchen Fitters' Talk' started by StuG, Sep 23, 2021.
  1. StuG
    StuG New Member
    For the common curved base units, what size radius is required for curving the worktops
  2. spen123
    spen123 Active Member
    I'd go same radius as base unit.
    Make a template
    StuG likes this.
  3. woodbutcherbower
    woodbutcherbower Well-Known Member
    As spen123 says above - the radii used by different manufacturers isn’t always the same, Draw the radius of a curved door onto a piece of 18mm MDF, carefully cut the curve with a jigsaw, and clean up any slight irregularities with a sander to make your template.
    Cut the curve using a router with a 50mm x 12.7mm two-flute cutter and a 30mm guide bush. With this setup, the template needs to be set up 9mm inbound from the worktop edge.
    StuG likes this.
  4. spen123
    I normally cut roughly out mdf or ply.
    Fit door and pjt frig tap top of door.
    Use a palm router and bearing bit riding against door to trim template.
    StuG likes this.
  5. CGN
    CGN Screwfix Select
    I’ve got a Howdens radius jig, obviously bought for one of their kitchens. One thing to bear in mind is the thickness of the edging. If you make a template, you need to think about that and offset it accordingly.
  6. woodbutcherbower
    Just found a couple of pics from a kitchen I did a few months back ... this template fits curved base units from a few different manufacturers - Howdens, DIY Kitchens, Wickes and Homebase. I've made three other jigs. This one was made from a leftover base end panel.
    773801C9-A271-4375-AA61-1ECE151FDC8C.JPG E8C89BDC-4E59-4C28-922A-0FAAA519E8B2.JPG
    CGN likes this.
  7. CGN
    CGN Screwfix Select
    Think the Howdens jig I’ve got is made by Unika, so prob good for a few brands. Hasn’t come out the garage in ages though.
  8. StuG
    StuG New Member
    Using that size radius, does the edging strip blend OK using square edge
  9. CGN
    CGN Screwfix Select
    It has 2 sets of dowel holes from what I remember. Either a flush radius, or an offset that allows for the thickness of the edge trim.
    StuG likes this.
