Got what we think is a wattle ceiling. Removed the artex from the original skim and got a smooth finish. High spots left are under 1mm. The appearance of the ceiling is marred by reminants of artex on the low spots. Any comments on: Currently suitability of the surface. Wash with mildly soapy water. Dry for a few days. PVA coat. Reskim. Could keep scraping but am trying to preserve ceiling integrity. Some small movement / flex when pushed right now, but not enough to suggest ata danger of falling to my inexperienced soul.
Bugger, was hoping to avoid, hence removing the Tex. Can I ask why this suggestion, is it the remnant crud, or amore fundamental issue. Also thanks for terminology!
Ok ta I really appreciate it. My time isa non issue, but money is (privately furloughed engineer!) so unless there is a fundamental issue I'll give it a go at the risk of spending more and learning a new skill...
Got any Y cracks... like a fork in the road as that's a week point. Can vac and pour plaster mix from above to strengthen but prop up from below. Any type of plaster mix wiii do. Use ready-mix smoother over and then sand. Maybe roll on smoother
Cheers guys, there are two 2ft sq areas where I have knocked out the plaster and will be reapplying because it is / was loose Appreciate the info to Isave me time, but am viewing this as a learning curve for private use! When I get bored in the next room I'll take your advice for shorter time!
Just watch those ceilings don't come down with a bump.. They show signs of failing then just come down. You don't want to be under it
