Hi, Just on getting my full house skimmed. I've removed all the old woodwork and I was planning on using an adhesive to reattach all the new skirting. However, I've noticed that the plasterer has left a gap at the bottom of the room on the ground floor (I believe this is to stop damp?) I was trying to avoid using nails or screws as I didn't want to risk ruining anything. What's the best way to attach skirting when it's like this? Do I just have to screw to the wall? What should I do if there's a pipe going along the bottom of the floor in the wall? (I chased the heating pipes into the wall downstairs) Thanks!
Could use expanding foam and wedges to hold till it sets... or if a timber floor screw a batton to the floor to hold the skirting board till the adhesive sets. Have use foam a few times and is a really good adhesive!plus it stops any draughts!
Cheapo stuff from our host is perfectly acceptable, just make sure to make sure its held firmly while it sets!
I'm with Dan P - use Instastik (or the pink equivalent) designed for the job, not a general foam. The adhesive versions a) have added adhesives and b) are lower expansion. (although I'm sure general foam is pretty good). If the surface is dusty, brush it off and spray a little water before using the foam - it helps it to go off. I have never found the need to add secondary screws/nails to MDF skirting - that stuff sticks like the proverbial and none of mine have ever come off... If timber a few fixings can help if there is a lot of spring in the timber, but otherwise just use foam.
Thanks for that, I'll give the insta stik a go. I'm planning on using MDF so sounds fairly straightforward.
