Slabtech warped
Discussion in 'Kitchen Fitters' Talk' started by Not-a-Decor8r, Mar 14, 2019.
  1. Not-a-Decor8r
    Not-a-Decor8r Member
    Hi,
    Just got these this week for kitchen, when putting the second worktop on with a join it appears to be raised about 0.5 mm on one end, visible with gap between unit and worktop.
    I've spoken to Sheridan who said it needs to have a bit of heat to resolve so will leave a heater in the kitchen tonight.
    Kitchen has been rather cold this week so is this what the 24/48 hours recommended period of leaving them in room temperature is effectively doing?
  2. kitfit1
    kitfit1 Well-Known Member
    As a rule, all worktops should be at room temp for at least 24 hours before machining and fitting. We all know though that in 99% of cases that simply is impossible when they are at full length.
    What we always try to do is cut them 50mm over length for each run and then move them into the house the day before actually fitting them. That won't in all cases get any bows out them by the way. That's because they would have been stored at the suppliers for weeks at the wrong temperature anyway.
    Jimmycloutnail and Not-a-Decor8r like this.
  3. Not-a-Decor8r
    Jeez a blowed...I've got a 1300w heater on them as I type, is it worth leaving this on in there all night or useless?
  4. kitfit1
    Useless to be honest. The tops need to be at room temp for 24 hours not loads of degrees above room temp.
  5. Not-a-Decor8r
    Bit weird the post I replied too has gone...maybe he was taking the P*ss.
    Makes sense to leave out to settle.
  6. kitfit1
    Not only has the post been removed, but the Troll that posted it has been removed as well :D
    WillyEckerslike likes this.
  7. Not-a-Decor8r
    Idiots...id already been down the garage and bought a tank of propane.
    Pics are what I'm seeing.
  8. kitfit1
    Before actually placing blame on the worktops, are you absolutely 100% certain that the base cabs are completely level ?
  9. WillyEckerslike
    For how long though?
    kitfit1 likes this.
  10. Not-a-Decor8r
    Yes.....
  11. kitfit1
    Almost certainly at some point or indeed any point........................the only certainty is he/they will be back.
  12. WillyEckerslike
    As dependable as an England middle order batting collapse.....
  13. Not-a-Decor8r
    0 in stock.....8 in another store
  14. Not-a-Decor8r
    1300w heater for a few hours...
  15. kitfit1
    I would still just leave it at room temp for 24hrs even if it has flattened out. And i would leave the worktop adhesive in the room for the same time.
