Sleeve for Clay Toilet Drain
Discussion in 'Plumbers' Talk' started by Jimbo, Oct 27, 2020.
  1. Jimbo
    Jimbo Screwfix Select
    Removed toilet to find clay drain in floor is cracked/broken near the top. Seems stable enough but I suppose this will need somehow sleeving down to below the crack? I'm not sure the pan connector will extend past all the cracked area.
    Any ideas how to proceed?
  2. kiaora
    kiaora Screwfix Select
    hi
    i suppose it's a matter of how bad is it cracked ?
    can the cracks be sealed ? when in normal use the flow in the vertical pipe won’t really be a problem,
    its only smell/sewer gas that can percolate and cause a problem ?
    good luck
    peter
  3. Jimbo
    Pretty badly cracked, but patched up with waterproof sealant and a longer pan connector ordered to make a seal deeper into the pipe past the cracked bit. Hopefully that will work.
    kiaora likes this.
