Small pond pump/fountain wiring??
Discussion in 'Electricians' Talk' started by Zelda, May 17, 2019.
  1. Zelda
    Zelda New Member
    Hi can anyone advise please. I have bought a small pump/fountain to put into a belfast sink to make a small pond. Now what I was going to do is, the old Ariel cable came through the side of window. Can I put the pump cable through that hole and use the socket inside?. The pond is about a foot from window/wall? Thank you
  2. spirits are real 2016
    spirits are real 2016 Active Member
    what is the window frame made from plastic, wood, or metal.
  3. Zelda
    Zelda New Member
    Its a plastic frame.
  4. spirits are real 2016
    then yes just run it through the aerial hole as long as there is no chance of the cable fraying or getting cut into by any sharp edges from the plastic.
  5. Zelda
    Zelda New Member
    Thanks for reply. And its ok to plug into socket in side?
  6. spirits are real 2016
    yes its fine to plug in doors as long as its 240 volts with a three amp fuse depending on rating.
  7. Zelda
    Zelda New Member
    Thank you
  8. spirits are real 2016
    do you have RCD protection in your consumer unit.
  9. Zelda
    Zelda New Member
    Yes I do. I am also getting a plug in circuit breaker. Thanks
