Smart Switches
Discussion in 'Electricians' Talk' started by Scott Middler, Jul 9, 2020.
  1. Scott Middler
    Scott Middler New Member
  2. CeSparky1
    CeSparky1 Active Member
    That seems to suggest if you dont use a neutral you require a capacitor which seems strange. Having a look seems like the capacitor comes with the switch so as long as you can fit it in should be ok.
    Have a look at quinetics wifi, not sure exactly what you want to do but they will save you having to have a neutral at the switch or use the cable at all. They fit above the ceiling and yes most smart switches require a neutral.
