I’m installing a washing machine. The existing socket is behind it. I’m a bit concerned as there maybe a point in the future where it could get wet. Leaks etc. Are there any covers etc, to avoid moving the socket? Cheers.
Could you fit an outdoor rated socket ip66rated, not an electrician just an idea. https://www.toolstation.com/bg-deco...VePVWdMvXvLCYBRvEEBoCU6wQAvD_BwE&gclsrc=aw.ds
normally there would not be the room to push a washing machine back with this behind it and either side are normally pretty tight too.
I generally find that washing machines aren't too bad but dishwashers usually require every available millimetre of depth.
