socket installation
Discussion in 'Electricians' Talk' started by RMH, Oct 15, 2006.
  1. RMH
    RMH New Member
    I was walking round one of the DIY sheds today and came across hollow skirting that once fitted has a 20mm cavity behind it, the bumph say's its ideal for concealing pipes/cables etc. I was wondering, are there any regs that forbid sockets being installed into this type of arrangement in a domestic dwelling? it would certainly beat chasing walls out etc.
  2. sinewave
    sinewave Screwfix Select
    It's used all the time in commercial offices.
    AKA Dado Trunking too!
  3. RMH
    RMH New Member
    This stuff is made out of wood and would obviously be at floor level, would it still be allowed?
  4. sinewave
    I don't see why not.
  5. Ripped Off
    Ripped Off New Member
    Yes.
    Got a load of flats to do, spec is to run cables behind the skirting.
    Not found any regs to say no. Cables at low level
  6. RMH
    RMH New Member
    Nice one
    I have to have some extra sockets fitted to a couple of the bedrooms and this would beat the hell out of chasing walls etc. Skirting looks nice as well, 8inch torus, perfect for the job.
    Thanks sinewave.
    I'm sure someone will come back with some obscure reg or something!
  7. RMH
    RMH New Member
    Cheers Ripped Off
  8. Ripped Off
    Apart from Nitros and his followers not many people hang pictures at that level LOL
  9. RMH
    RMH New Member
    Do you think its best to run the cable in some mini trunking or similar to contain it a bit?
  10. 2 wheeled ant
    2 wheeled ant New Member
    You can get cornice trunking been around 20years.
    Ant
  11. RMH
    RMH New Member
    must of been a bit of a sod plugging in the tv!
  12. Ripped Off
    No just clip it in place, prob find it will obstruct fitting the skirting
  13. 2 wheeled ant
    Easier than pulling up fixed flooring or expensive carpets.
    Ant
  14. RMH
    RMH New Member
    Thats it then, me off to the shed in the morning, new skirting it is.
    Just had a thought, would you still need to use a pattress or would you just bring the cables in to the back of the socket. I suppose you could always use a dryline pattress.
  15. RMH
    RMH New Member
    ant
    I totally agree with you on that one, the thought of ripping up the pitched pine flooring has been giving me nightmares!
  16. Ripped Off
    Chase the wall as normal and bring the cables up to the new socket. Dont fit them to the skirting
  17. RMH
    RMH New Member
    thanks, much appreciated.
  18. RMH
    RMH New Member
    As an aside, could you fit the sockets to the skirting if you wanted to?
    I feel a slagging comming my way
  19. 2 wheeled ant
    There a prob with plug top flex, 150mm
    Ant
  20. Coloumb
    Coloumb Screwfix Select
    Building regs in all just to be totally anal.
    450mm from floor...
