Socket under sink..
Discussion in 'Electricians' Talk' started by Camerabloke-02, Jul 13, 2019.
  1. Camerabloke-02
    Camerabloke-02 New Member
    I'm staying in a flat at the moment which has got a comprehensive water filter system under the sink.
    The water outlet for the filter system is directly above the electrical socket for the Dishwasher. Ie ie about 10cm above and if you disconnected the pipe without turning off the water it would gush onto the socket.
    The flats been recently done up and the consumer unit is metal with RCD/MCD's suggesting the electrics were done in the past year or so if I remember rightly (I'm not a spark but doing up my house at the moment, in conversations with the builders I understand the regs now stipulate metal consumer units).
    Surely this isn't safe is it?
  2. Coloumb
    Coloumb Screwfix Select
    Why would you disconnect the pipe without turning the water off?
  3. Camerabloke-02
    Only if you were a loony obviously but weirder things have happened... Or the joint starts to leak. It just seems odd to me to put a socket under the sink in such a way.
  4. peter palmer
    peter palmer Super Member
    I've got some downlights in my kitchen ceiling, a couple are right under the bath. Do you think I'm best removing them?
    PhilSo likes this.
  5. Hfs
    Hfs Active Member
    The socket should be installed suitable to its environment...Not likely to be splashed etc under normal circumstances.
  6. Camerabloke-02
    So this is OK?
  7. Hfs
    Hfs Active Member
    Not ideal but yes it’s fine as far as regs go in regards to it’s location... The lack of strain relief on the cable feeding said socket would be picked up on a report...Nothing a few clips wouldn’t sort out.
  8. peter palmer
    Location looks fine, done it like that many many times. Wiring looks iffy though.
  9. peter palmer
    Also the electrics getting a bit wet doesn't mean certain death for everyone in the kitchen. If it gets wet let it dry out.
  10. Rulland
    Rulland Screwfix Select
    Where does one draw the line, not build a house because it could burn down?.
  11. xednim
    xednim Active Member
    not sure what reg's says about it but replace the switch with external IP65 or so rated and will be safe
    btw RCD will save you anyway- eventual short electrical giggling to your body but no kill- unless you have hart problems or electronic gadget build in
  12. Coloumb
    Whats the thing in the circle?
  13. xednim
    lime scale filter, common on those days WM/DW
  14. Wayners
    Wayners Screwfix Select
    Seen the house fuse box under kitchen sink a few years ago.. Would of posted a picture on this forum had I been here then.
  15. Woloumbo
    Woloumbo Active Member
    the dishwasher solenoid.
  16. DIYDave.
    DIYDave. Screwfix Select
    ‘Thing’ in the circle is known as an ‘Aqua Stop’
    Supplied with several brands of washing machines and dishwashers, Bosch, Neff, etc
    It’s the cold feed hose to machine contained within an outer sleeve with wires running along it
    If feed hose splits or leaks this will be detected and water contained within outer hose
    Solenoid within the box part then cuts water off to machine
    Don’t know how common split hoses are these days but Aqua Stop supplied as standard to many appliances, although you can connect machine with a regular hose, nothing fancy :)
  17. Woloumbo
    its just an inlet solenoid to fill the machine.the cables open the solenoid when the dishwasher asks to fill.
    the cables are contained in the outer pipe to contain them.the outer pipe isnt to catch leaks.the solenoid is placed at the start of the pipe,which does prevent the supply hose being pressurised at all times.
  18. unphased
    unphased Screwfix Select
    Cable entry to the socket needs pushing in as there should be no basic insulation exposed outside the socket.
  19. robertpstubbs
    robertpstubbs Screwfix Select
    Also maybe use a grommet or gland, but it would only make a minimal difference.
  20. unphased
    You can't use a grommet or gland on that type of accessory its too brittle. The cable entry would be a knock out slot that's just tapped out. To be tidy a length of mini-trunking wouldn't be a bad idea either.
