Soil pipe room?
Discussion in 'Plumbers' Talk' started by Gazowl1975, Jan 15, 2020.
  1. Gazowl1975
    Gazowl1975 Member
    Will all baths have room round back side to run 110 mm soil pipe for a lav I've only done it once before was fine then tho had plenty of room I'd prefer to take it straight outside but it's not possible? Cheers
  2. KIAB
    KIAB Super Member
    Most baths there should be just enough room, all depend on the bath support legs/frame.
  3. rogerk101
    rogerk101 Screwfix Select
    I did up a bathroom about a year ago where I needed to fit the 110mm soil pipe from the toilet AND a 110mm air admittance valve under the back of the bath. We hadn't chosen the bath yet, but I did need to connect the toilet ASAP, so I researched all the bath tubs I might possibly use - double ended, single ended, centre taps/plug, etc. They all had more than enough clearance.
