Soldering Bellows - Flux
Discussion in 'Plumbers' Talk' started by Jimbo, Jul 22, 2020.
  1. Jimbo
    Jimbo Screwfix Select
    Got some expansion joints, stainless steed bellows with copper tails. What flux should I use to solder them?
    Manufacturer data sheet states:
    "When using soldered capillary fittings, do not over-heat. Shield the bellows from excessive heat. Most fluxes are chloride based and will attack stainless steel, best to use a phosphoric acid based flux. Clean off all residual flux."
    I currently use LACO regular soldering flux paste, which states "contains no zinc chloride to reduce corrosion concerns" - but doesn't list stainless steel specifically as suitable.
  2. timotay
    timotay Active Member
