Solid oak floor with underfloor heating
Discussion in 'Carpenters' Talk' started by Stormbringer, Oct 12, 2019.
  1. Stormbringer
    Stormbringer New Member
    Hi,
    I'm fitting a solid oak floor on top of a concrete base with underfloor heating.
    I was thinking of using sikabond AT80. Is this the best adhesive or is there anything better out there? Also where is the best place to purchase it?
  2. JustPhil
    JustPhil Active Member
    Best glue in the world won’t hold solid oak over underfloor heating. You should be using engineered flooring, and then follow whatever the manufacturer advises.
    Stormbringer likes this.
  3. Shytot
    Shytot Active Member
    Where do you live ? We use Ted Tedd flooring & their glue . They are based in Warrington..I agree with Phil use engineered flooring
  4. Stormbringer
    Yes I also agree but unfortunately the customer had already bought the boards before I got involved. Maybe I should have turned the job down. Devon
  5. JustPhil
    I’d let the customer know you’ve looked into it more and learned it’s not gonna work, maybe point them here https://www.google.co.uk/amp/s/www....ing-and-solid-wood-flooring-a-bad-idea/?amp=1
    If you do fit it, do so with no warranty, but they’re only gonna be disappointed when it inevitable fails and you don’t want that on your record, so I’d recommend they sell/return what they’ve got and start again.
  6. Stormbringer
    Cheers Phil,
    That's exactly what I was thinking. The job is quite challenging anyway as it's an old mill conversion so the room is a semi-circle. Also they have electric sockets in the floor?? (Can't figure that one out). It's nice to challenge yourself once in a while.
  7. wiggy
    wiggy Screwfix Select
    Look in to this
    Plenty about it on here too
  8. Stormbringer
    Nice one Wiggy, Have you used this yourself, looks too good to be true. Anyone out there used this? Phil have you an opinion on this product?
  9. wiggy
    There is loads of info on here about it.
  10. GrahamTaylor
    GrahamTaylor Member
    Years ago there used to be a flooring guy who posted here frequently (called Audi-Evo, I think) and had a flooring business up in the North-East. He used to recommend Elastilon very strongly. Have a look back at his postings.
  11. Stormbringer
    Cheers Graham,
    Just had a quick look but couldn't find any reference to Elastilon.
