I need to connect a 40mm solvent weld waste pipe to a 32mm compression fitting in a very tight space. Instead of using a compression reducer, is there a solvent weld solution which uses less space? Thanks.
Like this? https://www.toolstation.com/solvent-weld-reducer/p21595 Then add a piece of 32mm pipe into your compression fitting. Other retail outlets are available.
Deleted member 11267 doesn't miss much...how about this https://www.screwfix.com/p/floplast-reducers-40-x-32mm-white-5-pack/63577
I bet he misses DA. He seemed to enjoy venting at him occasionally. Actually, I used to quite enjoy reading those....
FloPlast WS50W might work, need a offcut of 32mm pipe. https://www.wickes.co.uk/FloPlast-W...VgrTtCh20Fwd-EAYYASABEgIxVfD_BwE&gclsrc=aw.ds
Never seen those before, if the 32mm pipe goes in further than it does on the other reducers then I like it.
About 29mm each end,so about same depth as on a solvent fitting I would think,haven't got one to hand to measure.
To illustrate the point Deleted member 11267 has made about using a 40mm coupling or bend to accept the 40-32 reducer, I’ve posted a couple of pictures of a ‘mock up’ This may help this post or maybe in the future, it’s a kinda Public Service Information Post so that’s my good deed for the day done So..... 40 and 32mm pipes 40-32 reducer 40mm coupling Semi assembled to illustrate, fittings not fully pushed home The description on SF page for the reducer is very misleading as doesn’t mention this won’t fit direct to the 40mm pipe and no mention of needing to use a coupler, bend, etc So, if you don’t know, you don’t know ! Hope this helps
Polypipe WS28 with a small length of 32mm? https://www.cwberry.com/Plumbing--H...WS28-32mm-Solvent-Waste-Reducer_M08106246.htm
