Hi, I have a shed leak issue. I purchased the shed 2018 but this year its showing leaks between horizontal boards, damp and floor leaks / damp. This was an ebay purchase! However labelled a very strong shed and it is with thick walls (21mm T&G) and sound structure. I further put this on a good base and thought I gave it a good treatment (Cuprinol Water Based). As you can see the leaks or seep is significant and ultimately risks rot on the inside. It seems to be drawn in through the T&G but water does appear to sit on the outside depressions. I realise I am going to have to wait probabaly to summer for this to dry out but what is my best course of action. Simply re-treat with alternative or something more drastic? Appreciate any thoughts or advice. thanks Gerard
https://photos.app.goo.gl/xV6YSfJjFioGuZsR7 Outside photo https://photos.app.goo.gl/TXCwTTG3Nd5eouTY9 Another inside photo
Its still half a story with those pictures. Best guess its coming off the roof, hitting the fence and splashing on the wall. Can you take a wider perspective photo, A picture of a damp spot is just that, its whats going on around it where the problem is.
Wiggy, the shed is kind of surrounded by hedge and stuff. However you touch upon something I just thought about myself that is the shed could do with some guttering down the length as its seems to be only the length or sides affected. Thanks
Guttering is essential. I'd get some cheap tarpaulin, cover the walls, let it dry out Then a good paint job.
+1 to T&G don't look right. Inside shot shows ingress along the join between individual planks as if there wasn't a tongue. Capillary action over the tongues? Water looks like it can sit in the joins on the outside, unlike featherboard or shiplap.
