Sound Insulation in Window
Discussion in 'Other Trades Talk' started by koolpc, Oct 21, 2016.
  1. koolpc
    koolpc Screwfix Select
    In my bedroom i have a new Double Glazed window with one big pane and a quarter light and a bigger opener under that.
    I hate noise and i can hear the hum of the motorway / roads in the distance.
    Is there anything i can do to stop that noise?
    I have heard of secondary glazing but we only just changed these windows! (2 weeks ago)
    Toughened glass in windows.
    No slack in openings as far as i can see.
    Astramax likes this.
  2. diy_nixy
    diy_nixy Active Member
    Wondering if it makes any difference when you pull the window shut even more tightly with your hand?
    Sure there aren't any gaps on the sides when fitted (between frame and wall)? All voids have been filled correctly etc.
  3. KIAB
    KIAB Super Member
    Take the trim off around frame & foam any gaps between frame & wall, use a low expansion foam, did front window here made quite a difference.
  4. koolpc
    There are no trim around as windows fitted snug
  5. koolpc
    No gaps at all. Is it easy to tighten window openings? They seem firmly shut.
  6. KIAB
    KIAB Super Member
    Bet if you removed a bit of plaster, you would find a gap between wall & frame.
  7. koolpc
    I dont plan on removing plaster! lol
  8. koolpc
    Its annoying for me as i can hear the 'humm' of the traffic in the distance! Drives me potty! lol
  9. Secondary glazing fitted about 6" from the fitted double glazed windows works , 4mm glass
  10. koolpc
    I would rather fix the glazing i have. Not much sill to play with
  11. KIAB
    KIAB Super Member
    Go to sleep then, you won't hear it then...:p
    Cheaper solution.
  12. koolpc
    Barsteward!
    KIAB likes this.
  13. KIAB
    KIAB Super Member
    Seems daff having to fit secondary glazing to solve a problem, prehaps you should have fitted tripple glazing.:)
    The problem has to be down to installation, any gaps between wall & frame should have been sealed, before plaster was made good.
    What about replacing glazed units with Pilkington Optiphon acoustic glass double glazing units.
  14. koolpc
    No plastering was done inside. A couple of thin plastic strips. Outside was a thin strip of plastic
  15. Astramax
    Astramax Super Member
    Remove the strips to gain access to the voids.
  16. KIAB
    KIAB Super Member
    Simple, abit slow to sink in,but the hour is late.:D
  17. koolpc
  18. KIAB
    KIAB Super Member
    Among the best Soudal Expanding Foam in my opinion, I use the gun grade versions, but some do expand alot, so don't go overfilling otherwise you'll spend hours cleaning up & trimming back.:rolleyes:
    And wear gloves using it, & moisten surfaces with a water sprayer prior to application.
  19. BMC2000
    BMC2000 Active Member
    This soundstage can be attenuated by having your double glazing different thicknesses of glass. So 4mm outer air gap and then 7mm would be what to go for. I did this for mine.
    The science is when sound hits the glass it resonates at a certain frequency and can transfer easier (ie louder) if the next pane is the same thickness.
    That's the starting point. If sound is still unacceptable, you look at secondary glazing.
  20. BMC2000
    Ps, double glazing as per the spec above is better at sound attenuation than triple glazing. Triple glazing better for heat retention.
