Soundproofing Water Pipes
Discussion in 'Plumbers' Talk' started by Mycal, Nov 30, 2021.
  1. Mycal
    Mycal New Member
    My flat has a concrete floor, and the water pipes run around the bottom of the walls, they are not boxed in , they're exposed. The water pipes of both flats seem to be all connected. Consequently when my neighbours, in the flat bellow, use their cold water tap, the noise penitrates right through every room of my flat.
    Can anyone advise me how to go about soundproofing my pipes, bearing in mind that its a rented flat and I don't want to spend too much?
    Thanks in advance
    Mycal
  2. pppmacca43
    pppmacca43 Super Member
    What sort of noise is it? I doubt you can soundproof the pipes, maybe boxing them in and packing with insulation would work but that’s not really gonna be that cheap. Ideally you would need to sort out the issue causing the noise, but if it’s your neighbours supply causing the noise it could be a pain. The actual issue could be as simple as a valve partially closed, which can cause a rushing sound.
  3. Mycal
    Mycal New Member
    pppmacca43
    Thanks for getting back to me.
    The noise the pipes make is a loud, sometimes high-pitched, or a deep bowelled noise, depending on how much my neighbours' tap is opened and how fast the water screaches through the pipes. Either way it's unpredictable and irritating. I think there is a pressure problem because when I turn my tap on it rushes out like Niagra.
    I wrapped some blankets around the exposed pipes in the kitchen earlier, just to see if it would muffle the sound a little. It has made a difference, so a more substantial job would definitely help. It's just a case of what material to use.
  4. pppmacca43
    I suspect if the pressure is high then a valve has been turned down to regulate the flow. This will cause a loud rushing noise through the pipes. Not really sure what you could try cheaply that will deaden the noise, maybe some pipe insulation could help
  5. Jimbo
    Jimbo Screwfix Select
    Could be worth reporting it to the landlord stating 'noise nuisance' - could be as simple as adjusting the main supply.
    just pumps and pppmacca43 like this.
  6. Mycal
    Mycal New Member
    Thanks for the advice. I will get a plumber to check pressure first. Then insulate.
    pppmacca43 likes this.
  7. Mycal
    Mycal New Member
    Thanks for the advice Jimbo. I will get a plumber to check it out, then insulate.
  8. pppmacca43
    They don’t really need to check pressure as such, that will be ok. When you have high pressure and a valve isn’t open fully it can create a noise. If as u say it only happens when the neighbour uses the water then that would most likely be in there house.
  9. Mycal
    Mycal New Member
    pppmacca43
    I have contacted the landlord, reported the issue, stating that the problem is likely to be found in the flat underneath mine. The landlord said they will inform their maintenance department, but as it's not considered urgent, it's likely to take some time. In the meantime I will have a go at insulating all the exposed pipes. I appreciate your advice. Thanks.
