Space between decking planks
Discussion in 'Builders' Talk' started by Jonesy, Sep 15, 2004.
  1. Jonesy
    Jonesy Member
    I have all the tools, all the timber, sa blooming great box of great think shank "green" 8x2.5" decking screws, a cordless drill and two spare batteries. Trouble is I have no idea what the gap should be betwene the deking planks, or why. The planks are 125mm wide and 38mm thick, grooved.
    Thanks
  2. Jonesy
    Jonesy Member
    ...and my spelling is atrocious!
  3. jasonb
    jasonb New Member
    5-6mm should allow for drainage and expansion / contraction without the risk of trapping stilleto heels and childrens fingers. Use a scrap of wood as a spacer, its quicker than trying to measure. Check every so often with a tape to make sure you are keeping parallel.
    Jason
  4. gadget man
    gadget man Screwfix Select
    I use a 4" nail to space the boards, nail head stops it falling through!!
  5. Dewy
    Dewy New Member
    And I'd use a good weedkiller on the ground beneath then cover with a weed control membrane before covering it with gravel. The decking would provide a good insulation for the soil beneath and help with the germination of any seeds that are blown in or dropped with bird droppings.
  6. owen
    owen New Member
    As gadget man says, a big nail will give the required clearance, about 3-4mm is sufficient. Get a 4" square peice of decking board, and hammer the nail through the centre - even less chance of it falling through then! Two of these make excellent spacers, one at each end.
  7. Measure2cut1
    Measure2cut1 New Member
    The replies above are for gaps of between 3mm and 6mm. It may be worth determining the length being decked and vary the spacing to avoid cutting a board at one end. Or if a board has to be sliced, to avoid a very thin slice.
  8. wilma
    wilma New Member
    A vert good point, you can see where he gets his name from!
  9. bodget&scarpers
    bodget&scarpers New Member
    fixed my own at 6m/m and gap in some places is now 14m/m :(
    just done 1 4 client and told him a 2m/m gap,which is now 5m/m!!!!
    so tthink it b me last one :)
  10. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Did my own decking. No gap. Busted my arms trying to squeeze them all as tight together as I could(some boards were well banana'd). Glad I put no gap. Three months later, regular 6mm gap. Boards were fresh and tanalised when purchased. I expected the shrinkage. They were sold as 144mm but I measured them when new at 148-149mm.
    Handyandy - really
  11. dunc
    dunc New Member
    Fit them about 2mm apart. They will shrink and the gap will open up to 5-6 mm. And that is enough.
  12. jasonb
    jasonb New Member
    Lot depends on the wood, Tanalised is usually wet so will shiink a lot, hardwood does not tend to move very much.
    Jason
  13. Jonesy
    Jonesy Member
    Thanks all.
    It's been a while since I asked for help but I'm glad I asked. Put in a gap at 3mm and now its about 5 or 7mm which is fine.
    Thanks again.
