Hi anyone got any recomendations on spindle moulders around £1K want to use it for small runs of oak joinery doors and windows etc. Thanks Shedmen
have a look at http://www.axminster.co.uk they have a selection of spindles which are quite reasonable. WB
For doors & windows which are usually 44mm finish you will need a machine that can take a 50mm high block or something like the Omas door/window sets so make sure the table recess and max tool dia are around 175-200mm and that the motor has the power to spin up a large steel tennoning block. Most of the smaller machines will not be upto it so you may have a job with a £1k budget. Come and have a look at this forum, search for spindles, the subject has come up quite a bit recently ref making doors/windows. Jason
Nice selection of big boy's toys, new and used from here : http://www.scosarg.co.uk/mall/departmentpage.cfm/scottandsargeant/79053/1/1
Thanks for advice so far will probably have to dig deeper as you say! Any recommendations on any reading matter on the subject? Thanks Shedmen
