Ind spark
Screwfix Select
Back to sleepI wouldn't listen to Industrial spark for electrical advice, he is a painter.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
People spur down gardens to sheds etc, so I wouldn't worry about spurring up into the loft.
Ok so found my multimeter eventually. so do I just do a continuity test on the neutrals (Blacks) in the socket I want to spur from or is there a better way?
Thanks
You are quite right to spur off a socket. Putting 13 a sockets (especially a double) is bad practice.Thanks for response.
The lighting circuit would be easier to spur from to be honest but I already have some spare 2.5mm T+E so thought I would use it up.
Is there any other way to double check the socket I'm spuring from is on the ring or is the amount of cables going to each socket (2, I presume one is in and is out) enough to confirm this?
Thanks
Of course it is not bad practice...... Putting single or double 13A sockets spurred to a ring final is standard. I've already suggested that you stop smoking that stuff.Putting 13 a sockets (especially a double) is bad practice.
OP, when you run up from the socket don't go through any moveable wardrobes as you may like new ones in the future and they will be hard to move with wires inside.
Strange comment I know but it's been suggested in the past.
Wish he'd make his flippin mind up.Of course it is not bad practice...... Putting single or double 13A sockets spurred to a ring final is standard. I've already suggested that you stop smoking that stuff.
Let’s correct that.Of course it is not bad practice...... Putting single or double 13A sockets spurred to a ring final is standard. I've already suggested that you stop smoking that stuff.
Why?Let’s correct that.
Putting a 13a socket (especially a double) on the lighting circuit is bad practice.
Let’s correct that.
Some time ago, there was another village idiot on DIYNOT by the name of Winston1.
I would say dangerous and in need of improvement.Why?
What code would you give it?
Dangerous...no
Potentially dangerous....no
Need improvement....no
Electricians that make up work I show the door.
The OP has already said he was going to do the right thing and spur from a socket.Are you suggesting a scenario from a previous idea of yours that involved putting electric fan heaters on top of a kitchen wall unit pointing downwards again?
A TV booster is going to be plugged in. That's all.
Or do you think the OP is going to do some baking in the loft and as soon as the Kenwood blender is called into action, all the lights will go out?
