Wellwisher
Screwfix Select
We all know that the regs have mistakes. That is why there are frequent amendments to rectify them.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
So the same mistake has been in the last goodness knows how many editions?We all know that the regs have mistakes. That is why there are frequent amendments to rectify them.
We don’t need a genius. How about a 5A BS546 plug and socket.Until some genius comes up with an approved connector system for these things to be used in attics its all you can do.
The OP has already said he was going to do the right thing and spur from a socket.
What about someone's makes up a lead using a 5 amp plug and a 13 amp socket and puts an oven in the loft?We don’t need a genius. How about a 5A BS546 plug and socket.
I dare you to name the regulation from the current edition of BS7671 that it contravenes. If you can’t or won’t name the reg, then it is neither dangerous nor in need of improvement.I would say dangerous and in need of improvement.
He can't, I've already given him the reg that permits it.I dare you to name the regulation from the current edition of BS7671 that it contravenes. If you can’t or won’t name the reg, then it is neither dangerous nor in need of improvement.
Indeed. I just wanted to see him attempt to justify the comment. I am sure we had this discussion a week or two back - he didn’t learn.He can't, I've already given him the reg that permits it.
yes, I recall that.Indeed. I just wanted to see him attempt to justify the comment. I am sure we had this discussion a week or two back - he didn’t learn.
Yes, he persists with nonsense even when presented with evidence to the contrary. His behaviour on the other forum ended up with him being removed permanently from there. I wonder if the mods here will take the same action, if we complain enough.yes, I recall that.
There must be something wrong with him.
Lets hope so.Yes, he persists with nonsense even when presented with evidence to the contrary. His behaviour on the other forum ended up with him being removed permanently from there. I wonder if the mods here will take the same action, if we complain enough.
You can make something foolproof but not idiot proof.What about someone's makes up a lead using a 5 amp plug and a 13 amp socket and puts an oven in the loft?
It does not need a fused plug. It is on a 6A MCB.Genius idea, put an unfused plug and socket on it, pure genius.
EICR are always someone’s opinion and in mine it is dangerous and in need of improvement.I dare you to name the regulation from the current edition of BS7671 that it contravenes. If you can’t or won’t name the reg, then it is neither dangerous nor in need of improvement.
And I’ve already said mistakes are made in the regs and that is why there are frequent amendments.He can't, I've already given him the reg that permits it.
Just as well you are not a real electrician then.EICR are always someone’s opinion and in mine it is dangerous and in need of improvement.
No, I think we should give 'Winston' a chance. Maybe @Wellwisher could post one of his EICRs on here. Maybe he's better than we think....Just as well you are not a real electrician then.
That is just a load of rubbish. Until recently they were made without plugs. Then when plugs became a requirement they were fitted. The same unit sold abroad are with local plugs WITHOUT fuses.The amplifier and cable assembly and its plug and fuse have been tested by the manufacturer, if the design called for a round pin plug it would have been fitted during assembly, a minor and somewhat pedantic fact maybe but one you may appreciate.
