Stabilising metal arch in garden
Discussion in 'Landscaping and Outdoors' started by james762, Jun 5, 2019.
Tags:
  1. james762
    james762 New Member
    Hi, so we've got a metal arch in the garden with a climbing plant on it. Didn't prune it much this year and now the plant is pulling the arch over. It's leaning at an alarming angle and we are worried it might collapse:
    The arch is just embedded into the ground.
    Looking for some views on what to do about this - without chopping the whole thing down!
    Thinking about some heavy pruning at the top to take the weight off, then some concrete around the legs to hold the arch vertical. Thoughts?
    Cheers :)
  2. sospan
    sospan Screwfix Select
    fit some hooks onto the shed and get some thick gauge florists wire and tie it to the shed
  3. KIAB
    KIAB Super Member
  4. Astramax
    Astramax Super Member
    Cut it down, re- set the arch and start again, securing it to the shed is a temporary measure and will not work long term..............it will grow again..........sometimes you have to make hard choices.
    Pollowick likes this.
