Stainless Kitchen Sink Eathing
Discussion in 'Electricians' Talk' started by redrobh, Dec 9, 2008.
  1. redrobh
    redrobh New Member
    Hi, just fitted new kitchen with a st/steel kitchen sink, this has an earthing tag, previous sink was plastic, do I need to run an earth to this if so can I pick it up from the kitchen ring circuit?
    Thanks
  2. JP.
    JP. Screwfix Select
    Hi Rudolph..there is no requisite to run an earth to tag on t'sink M8..:)
    Ps..please give Santa my regards.
  3. JP.
    JP. Screwfix Select
  4. Joelp1
    Joelp1 New Member
    the reason being that that would be supplimentary bonding which isnt required as a kitchen doesnt count as a special location.
  5. sinewave
    sinewave Screwfix Select
    Dom, no, Com yes! ;)
  6. redrobh
    redrobh New Member
    Thanks
  7. edward current
    edward current Active Member
    until you put the double insulated kettle on it with the damaged lead, plastic pipes, wet hands??????????
    i still think hey should be bonded
  8. multimick
    multimick New Member
    can i pick it up from the ring circuit f************ priceless :^O
  9. Lokkars Daisy
    Lokkars Daisy New Member
    It was common practice for electricians to bond sinks to the nearest socket earth
  10. Lokkars Daisy
    Dom, no, Com yes! ;-)
    Comercial kitchens are often bonded but this is not necessarily required ,it depends.
