Stainless Steel Brads on Siberian Larch Fence Slats
Discussion in 'Carpenters' Talk' started by James Kar, Jun 17, 2021.
  1. James Kar
    James Kar New Member
    Making a slatted fence with Siberian Larch 20 x 45mm P.A.R. Fencing.
    Ive been told by supplier that I must use stainless steel screws for fixing the slats to the posts. However, I would rather use 50mm stainless steel brads so that the screw heads are not visible. Is this a bad idea??
    Thanks
